  Visitors: 8233
CAD tip CAD tip # 5519:
Only partial drawing is plotted (plotter out of memory).
A - answer If you experience "Out of memory" problems when plotting a large drawing on your HP DesignJet plotter, either add RAM to your plotter or set the processing option.
In the Windows Start menu go to Settings > Printers. Right-click the plotter and select Properties. Set the driver to Process Document In Computer (most often in the Advanced tab). Your plot will be now processed on your computer, not in the plotter memory.
ACAD
100% *  CAD,PLT
20.4.2007    21393×   FAQ
Prices - CAD eShop:
applies to: AutoCAD ·
Tip 13040:iLogic - display information about complexity of an Inventor part.
Tip 12325:How to display a DWG from Advance Steel including AS objects? (AST viewer)
Tip 11195:How to download and install an update of Autodesk software - e.g. Revit 2017.1?
Tip 9843:How to add Classic workspace (toolbars) to AutoCAD 2015/2016 and higher?
Tip 9493:Inventor or AutoCAD or ReCap "stopped working" on a computer with two graphics cards.
