  Visitors: 4887
CAD tip CAD tip # 5615:
Launching an Office application starts AutoCAD installation dialog.
A - answer Trying to run Word or Excel starts an AutoCAD setup dialog prompting to insert the AutoCAD installation CD (configuration).
This is probably caused by an improperly installed Office add-on module (macro), which mistakenly refers to the last installed application.
Uninstall the complaining MS Office add-on module (e.g. scan utilities, convertors, document management integration tools, OCR, indexing services, etc.). You can also easily disable add-on modules through the security settings: in Word go to Tools > Macro > Security, and on the "Trusted publishers" (sources) tab uncheck the option "Trust all installed add-ins and templates". On next launch, Word will prompt you to enable the individual add-on modules and you can disable them.
ACADLT
15.6.2007    9846×
Prices - CAD eShop:
applies to: AutoCAD · AutoCAD LT ·
Tip 13597:How to convert RGB color to Pantone, RAL, AutoCAD ACI, CMYK or vice versa?
Tip 13296:How to correctly load a KML/KMZ file into Civil or Map 3D?
Tip 12926:How to import point coordinates from Excel to AutoCAD?
Tip 12884:How to insert your 3D model into a PowerPoint presentation?
Tip 11959:Supported file types (applications) with reference detection in Autodesk Desktop Connector.
