  Visitors: 4077
CAD tip CAD tip # 5666:
How to suppress the Read-Only warning on DWG file open?
A - answer There is no AutoCAD variable which could disable the Read Only message (dialog box).
But you can use a VisualLISP utility to open R/O DWG drawings without this message. You can even redefine your standard OPEN command:
(vl-load-com)
(command "._UNDEFINE" "_OPEN")
(defun C:OPEN ( / fn)
 (if (setq fn (getfiled "Open R/O" "" "DWG" 0))
  (vla-activate (vla-open (vla-get-documents (vlax-get-acad-object)) fn :VLAX-TRUE))
(princ "\nCommand OPEN redefined, use _REDEFINE to revert")(prin1)
Just load this LISP code into your AutoCAD session (with APPLOAD, automatically via .MNL, ACAD.LSP, etc.) and start the OPEN command. For scripts, use (getstring) instead of (getfiled).
See also Tip 2063 and especially the new Tip 10658.
ACAD
19.7.2007    16699×
Prices - CAD eShop:
applies to: AutoCAD ·
CAD Studio is not responsible for possible problems that may occur as a result of using any of these tips.
