  Visitors: 7767
CAD tip CAD tip # 5677:
How to print a multi-page PDF from AutoCAD?
A - answer You may want to plot (publish) multiple drawing sheets to a single PDF file, or plot the sheets as a single job (to be not interrupted with other jobs in your plotter queue).
In AutoCAD 2008 (and higher) you can use the PUBLISHCOLLATE variable (set it to 1) to publish (PUBLISH) all sheets and all selected DWG drawings in a single job, to a single multipage PDF file.
In AutoCAD 2007 or older AutoCAD versions and other CAD applications you can make use of DWFs. First publish a multisheet DWF and then print it from DWF Viewer (Design Review) to PDF over a PDF driver (pseudoprinter).
ACAD2010ACAD2009ACAD2008ACAD
27.7.2007    71050×   FAQ
Prices - CAD eShop:
Tip 13778:How to publish several DWG drawings into one multi-page PDF?
Tip 13773:What is the maximum paper size when plotting from AutoCAD?
Tip 13131:How to crop an image or PDF underlay in Revit?
Tip 11821:How to publish PDF sheets (pages) under the plain layout name?
Tip 10301:How to export PDF with hyperlinks from AutoCAD?
DwgTextTranslator translates a series of drawings from one language to another using MS Access.
Download a fully functional trial version.
