  Visitors: 3768
CAD tip CAD tip # 5692:
Cannot open a password protected DWG - "It contains incorrect or corrupted information".
A - answer AutoCAD 2007 may display an "incorrect/corrupted" error message trying to open a password-protected and encrypted drawing (and offers a RECOVER).
The drawing file is probably not corrupted - make sure you have installed the Service Pack 2 (or higher).
ACAD2007LT2007
8.8.2007    12845×
Prices - CAD eShop:
applies to: AutoCAD 2007 · AutoCAD LT 2007 ·
Tip 11479:"Assertion failed" error when launching AutoCAD.
Tip 11375:System error: The program can't start because mfc120u.dll is missing
Tip 11303:"Clock Error" when starting Autodesk CAD application.
Tip 11017:How to select a DWG object by its internal ID, its "handle"?
Tip 10557:Cannot change TAG in Plant 3D.
Increase your productivity with our set of add-on functions for AutoCAD Civil 3D
CADstudio Civil Tools More info
CAD Studio is not responsible for possible problems that may occur as a result of using any of these tips.
