New CADforum look launched.
Over 1.082.000 registered users (EN+CZ). New 1D nesting and 3D nesting tools, updated Color converter. New AutoCAD 2025 commands and variables. Learn about twiGIS.
Place your Ad on CADforum.cz
CAD tip CAD tip # 5697:
Question
If you need to select all objects inside a border defined by an existing polyline or circle, you can either use the WP/CP option of the object selection prompt and pick the individual polyline vertices, or you can use the WPS utility.
Load the WPS.LSP utility (see Download) and then use the WPS command or the transparent 'WPS option on the "Select objects:" prompt of any AutoCAD edit command. Pick the polyline or circle and all the objects inside it will be selected.
Finish the command to use the selected objects. If you use the standalone (not the transparent) WPS command, you can access its selection set in subsequent editing commands with the "P" (as Previous selection set) option.
The command prompts:
Command: MOVE
Select objects: 'wps
Pick a bounding circle or polyline:
Select objects:
Specify base point or [Displacement] :
ACAD
9.8.2007    60227×
applies to: AutoCAD ·
Tip 14250:How to select all lines of the same length or boundary polylines of the same area?
Tip 14192:MLfillet - how to fillet multilines in AutoCAD?
Tip 14177:How to scale an object to reach the target area?
Tip 14039:How to display the total volume or surface of 3D solids in DWG?
Tip 13938:ModDXF - utility for bulk modification/display of internal DXF properties in DWG entities.
Back    All CAD Tips
Categ:
Add .CIT raster format support to AutoCAD and Map and Civil 3D
CITin More info
