  Visitors: 4081
CAD tip CAD tip # 5711:
How to dimension arc length in Inventor?
A - answer You can dimension length of arcs either using a computed parameter (see Tip 3899), or - new in Inventor 2008 - directly using the application settings.
In Tools > Application options > Drawing tab, in the field "Drawing type preferences" switch the radius dimensions to "Arc length". Then you can use a standard arc dimensioning - its length will be displayed.
Arc length dimension
Inventor2008
25.8.2007    14555×
applies to: Inventor 2008 ·
Tip 13040:iLogic - display information about complexity of an Inventor part.
Tip 12479:PkLength - export line lenghts to Excel.
Tip 12392:Export unfolds of sheetmetal parts to DXF - parameters for iLogic and VBA
Tip 12350:PkArea - acreage of closed areas from DWG to Excel.
Tip 11989:How to dimension an ellipse in AutoCAD?
CAD Studio is not responsible for possible problems that may occur as a result of using any of these tips.
