  Visitors: 6979
CAD tip CAD tip # 5758:
Atomic iMate failed - error in Inventor.
A - answer This error may occur when a geometry referenced by an iMate is missing (no longer available) or temporarily not accessible (e.g. when you moved the EOP marker).
This generally indicates a user error or non-standard way in the modelling process. You may have deleted a face previously used for an iMate.
Inventor
21.9.2007    12101×
Prices - CAD eShop:
applies to: Inventor ·
Tip 13965:Total length of sweeps in Inventor - wires, pipes, trusses, tubes, hoses (iLogic)
Tip 13263:Error when renaming assembly files in Design Assistant 2022.
Tip 13227:Reference Explorer - quick analysis of your project or assembly (file size, xref errors).
Tip 13211:Automatic numbering/renaming of multi-volume bodies in a part.
Tip 13197:How to transfer a model or sketch parameter to iProperties?
VRMLout More info
