  Visitors: 10237
CAD tip CAD tip # 5800:
Model import error: Coincident face_face_ints with different body vertices
A - answer After a SAT or STEP import (ACISIN, STEPIN) of a 3D model, AutoCAD displays the message:
Failed to calculate silhouettes of a face.
Modeling Operation Error:
Coincident face_face_ints with different body vertices.
This is one of the error messages of the ACIS/Shapemanager modeller. There are probably overlapping faces, small (very thin) wedges or gaps in the imported 3D model. Try to locate the complaining body and fix it in the source application (e.g. Inventor).
You can also use the AMSTITCH function in Mechanical Desktop:
  1. Explode the part to an AutoCAD 3D solid
  2. Start AMSTITCH and select the solid
  3. In the Surface Stitching dialog, under Stitch Type, select Custom Stitching
  4. In the Operation area, select Heal gaps
ACADMDTACADM
16.10.2007    16313×
Prices - CAD eShop:
applies to: AutoCAD · MDT · AutoCAD Mechanical ·
Tip 13965:Total length of sweeps in Inventor - wires, pipes, trusses, tubes, hoses (iLogic)
Tip 13211:Automatic numbering/renaming of multi-volume bodies in a part.
Tip 13197:How to transfer a model or sketch parameter to iProperties?
Tip 13040:iLogic - display information about complexity of an Inventor part.
Tip 12532:Error when inserting standard part - Modeling: Failed to insert a part into assembly!
Generate hatch patterns automatically from your DWG drawings with
HGEN 2006 More info
