  Visitors: 8986
CAD tip CAD tip # 5806:
Edit blocks directly from table cells.
A - answer If you have legends and other tables with cells containing blocks, you may need to edit such blocks.
As there is no direct method for starting REFEDIT or BEDIT commands from the cell contents, the TCE add-on utility could help here. The TCE command lets you select a table cell and then starts the block editor on the block contained in the selected cell.
You can download the free TCE utility from Download.
ACAD2008ACAD2007ACAD2006
18.10.2007    8398×
Prices - CAD eShop:
applies to: AutoCAD 2008 · AutoCAD 2007 · AutoCAD 2006 ·
Tip 12926:How to import point coordinates from Excel to AutoCAD?
Tip 12830:Converting pseudo-tables consisting of lines and texts to TABLE objects in AutoCAD DWGs.
Tip 12743:A change in iLogic processing of Excel tables since Inventor 2021.
Tip 12671:Import Excel table by snapping a photo of it.
Tip 12479:PkLength - export line lenghts to Excel.
Add .CIT raster format support to AutoCAD and Map and Civil 3D
CITin More info
