  Visitors: 8365
CAD tip CAD tip # 5840:
Linetypes suddenly display as continuous.
A - answer After you installed Service Pack for a CAD application from the AutoCAD 2008 family, your linetypes may display as continuous (solid). Install the appropriate "Linetype hotfix" DL10188849.
ACAD2008LT2008Map2008ADT2008Civil2008ACADM2008
7.11.2007    8431×
Tip 13878:SelectSimilar - extended selections for AutoCAD, incl. LT and Web versions
Tip 13858:Is there also a SETBYBLOCK command?
Tip 13450:How to create a complex line type with text always upside down?
Tip 13435:Bulk setting of layer properties according to the object in that layer.
Tip 12837:RenameCSV - rename layers, blocks, layouts, views, linetypes using Excel tables
