  Visitors: 230
CAD tip CAD tip # 5910:
Undocumented benchmark utility installed with AutoCAD.
A - answer There is a hidden (undocumented) benchmark program installed with every AutoCAD (and AutoCAD-based program). You can use it to check the graphics performance of your PC.
The benchmark program comes in the GsTest.arx program file (in the AutoCAD folder). To run this benchmark, first load the ARX application (e.g. with the APPLOAD command) and then start it with the GSTESTBENCHMARK command (type it).
You will get results similar to this:
Wireframe      : 348.897695 ms
Wireframe      : 521.642884 fps
Hidden Line    : 349.936584 ms
Hidden Line    : 520.094235 fps
Flat Shaded    : 348.411879 ms
Flat Shaded    : 522.370249 fps
Gouraud Shaded : 347.433822 ms
Gouraud Shaded : 523.840768 fps
Other interesting commands defined in this addon application:
GSAUTOORBIT
GSDEBUG HUD ON
ACAD2011ACAD2010ACAD2008ACAD2006ACAD2004ADTCivil
18.12.2007    44253×
Prices - CAD eShop:
Tip 12101:Timing of any AutoCAD command - CMDtimer.
Tip 11433:Should I use Win10 Game Mode for my AutoCAD, Inventor or Revit?
Tip 5268:Make your AutoCAD faster on nVidia Quadro cards
Tip 3631:Make your 3ds max about 74% (up to 134%) faster!
Tip 2655:How to run standard benchmark procedures to show the PC performance in AutoCAD?
