CAD tip # 5950:
Tip 13985: | Advanced pressure drop calculations in Revit (multiple connections). |
Tip 13800: | Visually compare 3D geometry in CAD and BIM files. |
Tip 13227: | Reference Explorer - quick analysis of your project or assembly (file size, xref errors). |
Tip 12977: | Easily find CAD/BIM document references (including missing ones) - Reference Explorer |
How to cut a cylinder out of a wall?
Do you know the AIMLEADEREDITADD and AIMLEADEREDITREMOVE commands? « | » Maximum addressable memory in the individual Windows versions.
