  Visitors: 3207
CAD tip CAD tip # 5955:
Do you know the AIMLEADEREDITADD and AIMLEADEREDITREMOVE commands?
A - answer The commands with a little strange names AIMLEADEREDITADD and AIMLEADEREDITREMOVE are only slight modifications of the standard multileader editor - MLEADEREDIT. These undocumented commands are by default set to simplify adding and removing leader arrows in multileaders.
ACAD2008
24.1.2008    6772×
Prices - CAD eShop:
applies to: AutoCAD 2008 ·
Tip 12201:Quick dynamic measuring of objects near your cursor.
Tip 11841:How to set output folder for AutoCAD plot to file?
Tip 11794:Undocumented code in field expression - MText contents without control characters.
Tip 11160:Dynamic display of layer/block/text style/linetype properties.
Tip 10495:Support of STEP AP242 and STPZ in Inventor 2016.
DwgTextTranslator translates a series of drawings from one language to another using MS Access.
Download a fully functional trial version.
CAD Studio is not responsible for possible problems that may occur as a result of using any of these tips.
