  Visitors: 9540
CAD tip CAD tip # 5998:
How to disable the F1 key?
A - answer If you are frustrated by unintended launching of Help window when you hit the F1 key instead of the near ESC, you can switch off (suppress) this key, resp. map it to another, empty function.
Run the CUI command and expand the "Keyboard shortcuts" > "Shortcut keys" section". In the command list at the bottom select a "harmless" command, e.g. Cancel (by pressing "C"). Drag this command to the "Shortcut keys" section. In the bottom right panel Properties, set the access key for this command - select the item "Key(s)" in the Access field and click on the ellipsis button "...". In the field "Press new shortcut key" hit the F1 key. Save your settings.
The Help window can be then started through the pull-down menu or using the 'HELP command.
ACAD2008ACAD2007ACAD2006LTADT
24.2.2008    41026×
Prices - CAD eShop:
Tip 13571:Web application (FormIt, Fusion, AutoCAD...) is displayed distorted, with incomplete UI controls.
Tip 11623:Measuring suddenly doesn't work in AutoCAD or DWG TrueView.
Tip 11580:Excel: convert Unicode texts to \U+ codes for AutoCAD
Tip 11252:Applying STRETCH to 3D objects in AutoCAD.
Tip 9694:Random object colors in 3ds Max.
