  Visitors: 8735
CAD tip CAD tip # 6021:
How to toggle LT background color through a toolbar button?
A - answer You can use a Diesel macro utilizing the AutoCAD environment variable Background.
Add a custom menu or ribbon button (or even a keyboard shortcut) with this macro (a single line):
$M=$(if,$(eq,$(getenv,Background),0),
_setenv;Background;16777215,_setenv;Background;0);_TILEMODE;0;_TILEMODE;1;
TileMode change is added to redraw the model screen. Every click on this button will then toggle the background color of your Modelspace window between black and white (of course you can set also different color pairs).
For the background color in layouts, use the variable "Layout background" (incl. the space).
You can also change your model cursor (crosshairs) color in a similar way - try e.g.:
_setenv;XhairPickboxEtc;16777215
_setenv;XhairPickboxEtc;26844
This change is performed immediately.
And for layouts - e.g.:
_setenv LayoutXhairPickboxEtc 8364021
LT
14.3.2008    9965×
Prices - CAD eShop:
applies to: AutoCAD LT ·
Tip 14022:Comparing design versions in Autodesk Fusion.
Tip 13817:Cannot type decimal number in the transformation field in Autodesk Meshmixer (e.g. Scale).
Tip 13735:My initial login to Fusion 360 isn't working.
Tip 13372:How to create your own RFT file (Revit Family Template)?
Tip 13082:PDF published from AutoCAD shows blurred lines.
DwgTextTranslator translates a series of drawings from one language to another using MS Access.
Download a fully functional trial version.
