  Visitors: 5048
CAD tip CAD tip # 6031:
AutoCAD: Do you really want to do this?
A - answer AutoCAD may display the "Do you really want to do this" prompt if you are trying to hatch or manipulate a large set of objects on screen. You may also have used an xref as a hatch boundary - and the xref file may be damaged (try Audit) or it contains unresolved proxy objects.
A similar message (alert box) is: "Hatch object limit exceeded: More than 10000 hatch boundary objects are selected. Creating this hatch object can be time consuming. Do you want to proceed?". This one is caused by a very large object (entities) count on screen when picking a point in the BHATCH command. Try object selection or zoom closer to the hatched area.
ACADLT
20.3.2008    27988×
Prices - CAD eShop:
applies to: AutoCAD · AutoCAD LT ·
Tip 13504:How to add own commands to AutoCAD custom palette?
Tip 13158:ScaleBB - scale multiple objects to their ref.points or bounding boxes
Tip 13150:How to hatch selected objects including overlays and islands?
Tip 12966:TrimArr - trim a dynamic array to a boundary curve.
Tip 12633:Sol2SolH - convert DWG objects of the type Solid to Hatches
Add .CIT raster format support to AutoCAD and Map and Civil 3D
CITin More info
