  Visitors: 8366
CAD tip CAD tip # 6055:
How to switch AutoCAD 2009 back to the original UI with pull-down menus?
A - answer AutoCAD 2009 and LT 2009 starts by default with the new user interface (UI) utilizing the Ribbon. If you prefer to revert back to the classic interface, you can close the ribbon (the RIBBONCLOSE command) and enable the pull-down menus - set the MENUBAR variable to 1.
You can achieve similar results also by switching your workspace to the predefined status "AutoCAD Classic" (with the WSCURRENT variable or by clicking on the gear icon on the right side of the bottom status line).
ACAD2009LT2009
31.3.2008    43150×   FAQ
Prices - CAD eShop:
applies to: AutoCAD 2009 · AutoCAD LT 2009 ·
Tip 8484:How to apply material to a single face only?
Tip 8436:The RegistryVersion codes for individual versions of Inventor.
Tip 7937:AutoCAD freezes trying to Open a DWG drawing.
Tip 7852:Put Google Earth maps directly into AutoCAD.
Tip 7847:FIND does not stay zoomed on the found text.
DwgTextTranslator translates a series of drawings from one language to another using MS Access.
Download a fully functional trial version.
