  Visitors: 4994
CAD tip CAD tip # 6070:
Database Schema is newer than this version of the software.
A - answer This Inventor error message indicates that the opened IPT, IAM or IDW file was created in a newer Inventor version.
MCAD applications generally do not support data files from newer versions of the same software (the versions using a higher version of the modeling kernel). To tranfer your data, use one of the data exchange formats - e.g. STEP or IGES.
Inventor
7.4.2008    14724×
Prices - CAD eShop:
applies to: Inventor ·
Tip 13152:Compatibility of Autodesk products with Windows 11.
Tip 12962:True 3D models of threads in Inventor 2022 and 2021.
Tip 12856:How to force Inventor holes in existing points only?
Tip 12743:A change in iLogic processing of Excel tables since Inventor 2021.
Tip 12671:Import Excel table by snapping a photo of it.
LogOff 2006 More info
CAD Studio is not responsible for possible problems that may occur as a result of using any of these tips.
