CAD tip # 6106:
applies to: AutoCAD 2009 · AutoCAD 2008 · AutoCAD LT · AutoCAD Architecture · AutoCAD Map 3D · Civil 3D · |
Tip 12215: | How to change truecolor DWG objects to indexed ACI colors? |
Tip 11967: | How to apply a changed drawing template (DWT) to existing drawings? |
Tip 9829: | DrGrid - parametric grid for AutoCAD drawings. |
Tip 8515: | How to delete all Frozen or Off layers? |
Tip 8451: | How to lock layers without changing their color? |
How to draw a frame around the dimension text?
Very slow Xrefs, block insertions, copying objects; bloated files. « | » Arithmetic expressions in AutoCAD dynamic input fields.
