  Visitors: 4809
CAD tip CAD tip # 6199:
How to disable the PLOT.LOG file?
A - answer You can suppress writing of the AutoCAD plot log file PLOT.LOG by the following settings:
  • In the Options dialog, the "Plot and Publish" tab, the Plot and Publish log file option
  • In the Plot Stamp dialog (PLOTSTAMP), the Advanced button, the Log file option (PLOT.LOG)
To switch off the plot logging automatically, add the following command to your AutoCAD startup sequence:
(command "_-PLOTSTAMP" "_LOG" "_NO" "PLOT.LOG" "")
ACADLTADTCivilMapACADM
6.7.2008    35538×
Tip 11469:Why you should not use the DEFPOINTS layer to draw geometry?
Tip 9331:What is contextual field and why it is not updated in a block?
Tip 1862:How to stop making a .LOG file in AutoCAD?
