  Visitors: 8008
CAD tip CAD tip # 6242:
Toggling between layer freeze and layer off in the LAYOFF command.
A - answer The AutoCAD command LAYOFF (former Express Tools command) can either freeze or just switch off the selected layer when used in viewports.
You can set its behaviour through the settings option: LAYOFF > Settings > Viewports: off/freeze. In both cases, the layer will disappear, but frozen and switched off layers behave differently in many cases.
ACAD
1.8.2008    11053×
Prices - CAD eShop:
applies to: AutoCAD ·
Tip 13822:Fast layer visibility toggle ON/OFF.
Tip 12705:How to disable osnaps for xref objects?
Tip 11469:Why you should not use the DEFPOINTS layer to draw geometry?
Tip 8515:How to delete all Frozen or Off layers?
Tip 7547:Editing wall cleanup "in place" causes error in AutoCAD Architecture.
VRMLout More info
