  Visitors: 9404
CAD tip CAD tip # 6246:
New drawing with template selection.
A - answer If you want to start your new DWG drawings with the choice of predefined drawing template files (DWT), including the option to start from scratch, you can enable the "StartUp" dialog for the NEW command and for AutoCAD startup (the default behaviour in older AutoCAD versions).
The startup dialog option is no longer available in the Options dialog but you can set it through the STARTUP variable. So if you often select from multiple templates or if you create blocks where you don't want to carry in the overhead from template files, enable this option for starting new drawings.
6.8.2008    7232×
Prices - CAD eShop:
applies to: CAD ·
Tip 13056:How to copy DWG Properties from one drawing to another?
Tip 11967:How to apply a changed drawing template (DWT) to existing drawings?
Tip 10647:How to store macros inside DWG drawings?
Tip 9800:How to change the default display style for Ortho views in Plant 3D?
Tip 9133:Drawing not created by a product from Autodesk Education Suite.
DwgTextTranslator translates a series of drawings from one language to another using MS Access.
Download a fully functional trial version.
