  Visitors: 9037
CAD tip CAD tip # 6254:
How to convert an AutoCAD DWG to CorelDRAW CDR file?
A - answer There is no reliable standalone converter but newer versions of CorelDRAW (10, 11, 12, X4, X5) directly support import of DWG files (in older AutoCAD formats). Due to the complexity of the DWG format this import might be unreliable - so convert your drawing data rather via the exchange formats DXF, WMF, EPS, or PLT (HPGL). All these formats can be exported from AutoCAD and reliably imported into CorelDRAW.
Similarly for backward conversions of .CDR into .DWG files, do not use the DWG export offered in CorelDRAW. It does not create official DWG-format files and such "forged" drawing files may cause problems during further processing. Again, use rather the AutoCAD text format - DXF, or WMF.
ACADLT
8.8.2008    140298×
Prices - CAD eShop:
applies to: AutoCAD · AutoCAD LT ·
Tip 12120:Double-click to edit raster images in DWG drawings.
Tip 10432:How to open files in A360 Drive from Inventor or any other application?
Tip 6468:CorelDRAW Graphics Suite X4 collides with Inventor and AutoCAD Mechanical 2009.
Tip 3159:Uniform scaling of an entity using grips.
Tip 31:How to draw barcode in AutoCAD drawings?
VRMLout More info
