  Visitors: 7351
CAD tip CAD tip # 6287:
Work easier with AutoCAD groups.
A - answer AutoCAD LT - unlike the full AutoCAD with its GROUP command - contains simplified versions of commands for manipulating object groups - PKFSTGROUP and QKUNGROUP.
Many users are satisfied with these quick and simple versions of the group commands and the full dialog-based command GROUP slows them down. In addition, for ungrouping you have to specify the name of a group.
So we have prepared a free LISP utility GRP.vlx with the commands GRP and UNGRP. It can be used as a replacement of AutoCAD LT's group commands. You can use CUI to assign the GRP and UNGRP commands to keyboard shortcuts (recommended: Ctrl+Shift+G and Ctrl+Shift+U), or add them to your shortcut menu (context). Then just mouse-select any objects and press Ctrl+Shift+G -- they will be grouped. Or select a group, press Ctrl+Shift+U, and the group will be scattered again into the individual entities.
Both commands accept also pre-selected objects (grip-selection). They use unnamed groups.
You can download the GRP utility from Download - load it (permanently) using the briefcase in the APPLOAD command.
ACADLT
27.8.2008    16605×
Prices - CAD eShop:
applies to: AutoCAD · AutoCAD LT ·
Tip 13091:3DSolSz - list of dimensions of selected 3D solids.
Tip 13013:Converting a 3D mesh to a 3D solid in Fusion 360.
Tip 12403:Get center point of a group of selected objects.
Tip 12237:UnfoldRS - unfold 3D surfaces to 2D in AutoCAD.
Tip 12036:Sel2BlkRef (blockify) - replace repeating objects with block references
VRMLout More info
