New CADforum look launched.
Over 1.082.000 registered users (EN+CZ). New 1D nesting and 3D nesting tools, updated Color converter. New AutoCAD 2025 commands and variables. Learn about twiGIS.
CAD tip CAD tip # 6305:
Question
If you need to lock quickly all viewports (views) in all paperspace layouts, you can use the LockAllVp utility available on Download.
Just load it and run the simple LockAllVp command. All vports (including non-rectangular viewports) will be locked automatically.
ACAD
12.9.2008    20631×
applies to: AutoCAD ·
Tip 12837:RenameCSV - rename layers, blocks, layouts, views, linetypes using Excel tables
Tip 12448:Pan view (change view target) in multiple viewports of a layout.
Tip 9265:RENAME on steroids - complex renaming of AutoCAD objects (blocks, layers...)
Tip 5713:How to switch off UCSFOLLOW in all viewports of all layouts?
Tip 3968:Less known options of the (ssget) LISP function
Back    All CAD Tips
Categ:
VRMLout More info
