  Visitors: 11659
CAD tip CAD tip # 6352:
How to get your AutoCAD serial number?
A - answer If you need to find the serial number of your AutoCAD, AutoCAD LT, AutoCAD Mechanical, AutoCAD Architecture, AutoCAD Civil 3D or other AutoCAD-based application, you can use several methods.
  1. List the value of the *_PKSER variable (enter as a command on the AutoCAD commandline)
  2. Use the command ABOUT and display the product information window
  3. List the Registry key SerialNumber in a Registry hive corresponding to your application - e.g.: HKLM\SOFTWARE\Autodesk\AutoCAD\R17.2\ACAD-7001:409
  4. List the license activation report file - see the Tip 3511
To get your AutoCAD serial number for installation please see the sticker on the package of your installation DVD, or the delivery documentation, or the serial number provided by your AutoCAD authorized dealer or Autodesk.
ACADLTADTCivilMapACADMABS
16.10.2008    305286×
Tip 9661:Where to find the Portable license utility (PLU) in AutoCAD 2010, 2012, 2014 and higher?
Tip 8581:How to change AutoCAD serial number?
Tip 7837:Where to find the Product Key for your CAD software?
Tip 6951:Can I legally use a second copy of AutoCAD on my other PC?
Tip 6519:How to get your Revit serial number?
