  Visitors: 4195
CAD tip CAD tip # 6365:
The "Select similar" function also in plain AutoCAD.
A - answer The function "Select similar" (the command SELECTSIMILAR, resp. AecSelectSimilar - see the menu Edit and the object context menu) is in older versions (pre-2011) available only in the AEC versions of AutoCAD (AutoCAD Architecture, AutoCAD MEP, AutoCAD Civil 3D).
Using a simple LISP expression you can add this functionality also to a plain AutoCAD. Add the following expression (command) to a toolbar button or context menu:
(cadr(sssetfirst nil (ssget"_X"(list(cons 0(cdr(assoc 0(entget(car(entsel"\nSelect object and all similar: "))))))))))
This function can be then used either in the normal command mode - after you select an object, all entities of the same type are grip-selected; or you can use it on the standard "Select objects" prompt - there it includes the selected object and all similar objects in a standard selection set of an editing command.
Another option is to use the expression:
(ssget(list(cons 0(cdr(assoc 0(entget(car(entsel"\nSelect object and all similar: "))))))))
This function also prompts for a sample object. Then it asks for a standard objects selection. From these objects, only those objects will be used which are similar (the same type) to the sample object.
ACADADTCivilABS
29.10.2008    38921×
Tip 13716:HYPERLIST - list of all used URLs.
Tip 13694:Individual modification of elements in AutoCAD dynamic arrays.
Tip 13688:How to select all DWG objects of a certain type in AutoCAD LT? (texts, circles...)
Tip 13604:Importing points from a Shape file as symbols/blocks mapped to object data.
Tip 13561:Beware of "permanently" hidden objects in DWG drawings.
Add .CIT raster format support to AutoCAD and Map and Civil 3D
CITin More info
