CAD tip # 6389:
applies to: Civil 3D · |
Tip 10589: | Fusion 360 doesn't create a drawing, error Unknown command "0.0000,1.0000,0.0000" |
Tip 10310: | How to export a 3D model from AutoCAD to Navisworks? |
Tip 9905: | Double-click on a text gives: Unknown command DDEDIT. |
Tip 8875: | Select all does not work: Unknown command "AI_SELALL". |
Tip 8587: | My AutoCAD 2013 reports WORKFLOW as an unknown command. |
Brain Exception - an unhandled exception in your brain.
