CAD tip # 6397:
Tip 14053: | Why doesn't my export from Civil 3D to IFC 4.3 export surfaces and solids? |
Tip 13967: | Drawing polylines using arbitrary length units - 2DpolyC. |
Tip 13855: | DBXscanLayers and DBXscanBlocks - bulk report content of DWG files in a folder. |
How to lock several viewports at the same time?
My AutoCAD does not recognize the PDFATTACH command. « | » Next available number in AutoCAD Civil 3D.
