  Visitors: 11425
CAD tip CAD tip # 6403:
Select all specific texts in a drawing.
A - answer You can use severel methods to select all texts of a specific type (value) in a drawing. Let us have a drawing containing three separate text objects (Dtext/Mtext): Adam,Bravo,Charlie. Our goal is to select the text entities Adam and Bravo.
The simplest way is to use the FILTER command. In the filter type choose Text, value and in the X field enter [AB]* (see wildcard characters in Help). Click the "Add to list" button and use the filter.
Another option is to use a filter in the AutoLISP selection function - (ssget). For the requested type of selection, this function would read:
(ssget "_X" '((0 . "TEXT,MTEXT")(1 . "A*,B*")))
You can enter this LISP expression directly on the "Select objects" prompt.
ACADADTACADMCivil
19.11.2008    40015×
Tip 13737:Formatting leading zeros in AutoCAD fields (and automatic field update).
Tip 13716:HYPERLIST - list of all used URLs.
Tip 13688:How to select all DWG objects of a certain type in AutoCAD LT? (texts, circles...)
Tip 13049:Bulk 3D rotation of selected objects around individual axes.
Tip 12210:How to erase a specific object type in all DWG layouts?
Link your AutoCAD block attributes with Excel tables/sheets. Automatically. Dynamically. Bidirectionally.
Try Excellink 2015 More info
