  Visitors: 4534
CAD tip CAD tip # 6409:
Batch-print multiple layouts in AutoCAD LT 2008.
A - answer AutoCAD LT 2008 by default does not allow to batch print multiple layouts (multiple drawings) in one go - only to publish them to DWF.
The PUBLISH command (File > Publish...) starts a dialog where the option "Plotter named in page setup" is missing and you can only use the DWF output.
But another method of the Publish function does not have this limitation. First select (Shift+mouse on the tabs) several layouts to print, right-click on them and choose "Publish selected Layouts" from the context menu. In this case, the missing button (option) is shown in the publish dialog and so you can plot also directly to your plotter.
LT2008
1.12.2008    26366×
Prices - CAD eShop:
applies to: AutoCAD LT 2008 ·
Tip 13635:How to speed up background publishing in AutoCAD?
Tip 9968:Batch conversion of CAD files from/to the IPT/IAM, STEP, IGES, SAT, Catia... formats
Tip 8425:Batch print for multiple drawings, multiple printers and copies.
Tip 7585:Plotting/exporting a series of drawing frames composed in a DWG drawing (or creating layouts).
Tip 5717:AutoCAD suddenly publishes multiple drawings to a single PLT file.
