  Visitors: 6018
CAD tip CAD tip # 6422:
Which raster format to choose for transferring images?
A - answer If you need to send an output of a CAD application, rendering, photo, map or another picture over e-mail, or to otherwise transfer it electronically, and you cannot use a vector format, it is important which of the many raster formats you choose. You can significantly influence the file size and quality of the image. Each file format has its advantages, disadvantages and recommended usage.
FormatAdvantagesDisadvantages
BMPAlmost none, maybe: general availability on the Windows platformsvery inappropriate format, do not use; format is not compressed - resulting file is unnecessarily large
GIFEfficient, compressed lossless format, suitable for transferring screen captures, CAD data, maps, schematics, logos, etc.; transparency option8-bit color depth, limited palette of 256 colors - do not use for renderings and photos
JPGVery efficient, well compressed lossy truecolor format, well suited for transferring photographs and pictures where a loss of some pixels is not importantlossy compression, makes artefacts in the picture, blurs edges - do not use for CAD data
PNGCombines the advantages of GIF and JPG, compressed truecolor format, well suited for transferring accurate images, including CAD data, features alpha-channel (transparency)not so efficient format in terms of the file size
TIFCompressible format for professional use - maps, scanned drawings, suitable for CAD and GIS data (monochrome and color)too many variants and sub-types, not all of them fully supported; not so widespread
All of these formats can be exported and imported from/to AutoCAD, most of them are supported also in Revit and Inventor.
ACADDWG
4.12.2008    15928×   FAQ
Prices - CAD eShop:
applies to: AutoCAD · DWG ·
Tip 12881:How to attach multiple raster images to my DWG in one go?
Tip 12609:Dynamo - how to convert a raster photo to 3D model in Revit?
Tip 11790:How to get a hi-res image of an Inventor assembly (for a brochure, billboard...)?
Tip 11159:How to load an ECW v3 format image in AutoCAD?
Tip 9698:Data formats supported in Autodesk InfraWorks 360.
VRMLout More info
