  Visitors: 6814
CAD tip CAD tip # 6480:
How to display full path to a DWG drawing in AutoCAD window title?
A - answer You can enable showing the full path of your drawing file (disk, folder/directory, filename) in AutoCAD title bar by checking the "Display full path in title" box on the "Open and Save" tab of the OPTIONS dialog.
This setting is stored in the Registry (profile, ShowFullPathInTitle).
ACAD2012ACAD2010ACAD2008
15.1.2009    21558×
Prices - CAD eShop:
applies to: AutoCAD 2012 · AutoCAD 2010 · AutoCAD 2008 ·
Tip 13855:DBXscanLayers and DBXscanBlocks - bulk report content of DWG files in a folder.
Tip 13826:Overview of a document history in Autodesk Docs.
Tip 13557:How to create an image with transparent background in Fusion 360?
Tip 13522:LookupXLS - populating DWG texts from Excel spreadsheets.
Tip 13513:How to quickly record a video from a CAD application or other Windows program? (replacing Screencast)
