  Visitors: 4893
CAD tip CAD tip # 6501:
Convert entities or entity colors to separate layers.
A - answer For some external applications (e.g. rendering applications, CNC, calculation programs), it is neccessary to split the DWG drawing into individual layers grouping the same color (e.g. for subsequent assignment of a rendering material), or even to put each drawing entity into its separate layer.
The applications Xanadu Col2Lay and CADstudio Ent2Lay can help in these situations.
Col2Lay processes the selected drawing entities (objects) and moves (separates) all their individual colors (both individually assigned and "ByLayer") into individual layers. It automatically creates layers named by the ACI colors used - "XCL1" to "XCL255". The original (no more used) layers are purged. The drawing blocks are also converted (except the "ByBlock" color, which is not defined globally).
Ent2Lay has a simpler functionality - it moves the selected entities to new, individually defined layers. So each new layer contains a single entity of the original drawing. The layers are named by the type and handle of the original entity - e.g. "XENT_CIRCLE_1E3", "XENT_LINE_385".
Both free applications can be downloaed from Download.
ACAD
26.1.2009    9890×
Prices - CAD eShop:
applies to: AutoCAD ·
Tip 14072:How to import an STL, OBJ or 3DS file to an AutoCAD 3D model?
Tip 13847:Pringles in AutoCAD - a hyperbolic paraboloid.
Tip 13831:ReplMTcol - recoloring parts of text in paragraph Mtext.
Tip 13578:Change the block attribute type from variable to constant or vice versa.
Tip 13557:How to create an image with transparent background in Fusion 360?
LogOff 2006 More info
