  Visitors: 3751
CAD tip CAD tip # 6535:
Cannot delete a drawing layer (contains objects).
A - answer If AutoCAD does not allow to erase a layer (refuses purging), complaining that it contains objects, use the LAYDEL command.
This command deletes a layer including all its remaining objects, including any object elements laying in the particular layer.
ACAD
13.2.2009    10554×
Prices - CAD eShop:
applies to: AutoCAD ·
Tip 12036:Sel2BlkRef (blockify) - replace repeating objects with block references
Tip 11898:Automatic schedule - number of blocks in a drawing.
Tip 11054:Difference volume (3D solid) between two TIN surfaces (sets of coordinates)
Tip 9949:One layout view doesn't display border, cannot be selected.
Tip 9265:RENAME on steroids - complex renaming of AutoCAD objects.
CAD Studio is not responsible for possible problems that may occur as a result of using any of these tips.
