  Visitors: 7259
CAD tip CAD tip # 6544:
How to set a coordinate system with a single button?
A - answer If you often need to change or assign a coordinate system in your drawings (maps), you may need a commandline version of the coord.systems command in Map (a dialog-based command by default).
You can use e.g. the following LISP macro:
(defun C:SetWGS ()
(setvar "CMDDIA" 0)
(command "ADESETCRDSYS" "_ses" "LL84" "_ex")
(setvar "CMDDIA" 1)
(princ)
The newly defined command SetWGS can be then assigned to a toolbar button or keyboard shortcut.
Another - simpler method is to use the LISP function:
(ade_projsetwscode "LL84")
Map2009Civil2009TB2009
24.2.2009    12250×
Prices - CAD eShop:
Tip 13784:Export block coordinates to a table. How to use the DATAEXTRACTION command in AutoCAD LT?
Tip 13692:What is the precision in Revit?
Tip 13514:Why does the Power dimensioning command zoom my drawing?
Tip 13296:How to correctly load a KML/KMZ file into Civil or Map 3D?
Tip 13234:How to place a GeoTIFF image automatically into the correct position?
