  Visitors: 8803
CAD tip CAD tip # 6546:
How to set transparent color for my own AutoCAD icons?
A - answer If you need to create a partially "transparent" toolbar icons, you cannot use standard ways of PNG format with alpha-channel or transparent GIF files - AutoCAD (up to 2014) supports only icons in the BMP format which doesn't work with transparency.
But you can use a trick - the color with the hue of 192-192-192 (RGB) used in BMP icons is interpreted by AutoCAD as "transparent". Since 2015 you can use PNG icons with transparency. Since 2017 the 192,192,192-trick doesn't work anymore and PNG is the only option for transparent icons.
ACAD2009ACAD2008LTADT
24.2.2009    13232×
Prices - CAD eShop:
Tip 13822:Fast layer visibility toggle ON/OFF.
Tip 13504:How to add own commands to AutoCAD custom palette?
Tip 13459:DWG drawing version history directly in AutoCAD.
Tip 10808:How to make transparent icons for my CUI ribbon in AutoCAD 2017.
Tip 10204:How to attach an .AdskLib material library in AutoCAD?
VRMLout More info
