CAD tip # 6558:
applies to: AutoCAD · AutoCAD LT · AutoCAD Architecture · Civil 3D · AutoCAD Map 3D · AutoCAD Mechanical · |
Tip 13737: | Formatting leading zeros in AutoCAD fields (and automatic field update). |
Tip 12697: | Opposite angle for angular dimensions in Inventor drawings (iLogic). |
Tip 12201: | Quick dynamic measuring of objects near your cursor. |
Tip 10412: | How to enter angles in survey units? |
Tip 10314: | How to enter angles in the format degrees-minutes-seconds in Inventor? |
Brain Exception - an unhandled exception in your brain.
Arithmetic expressions in AutoCAD dimensions. « | » How to set transparent color for my own AutoCAD icons?
Featuring: Add .CIT raster format support to AutoCAD and Map and Civil 3D CITin ![]() |
