  Visitors: 964
CAD tip CAD tip # 6581:
US projection in Inventor drawings.
A - answer If you want to switch Inventor to the "american" projection type (railway projection), you can find this setting in the Style editor:
Inventor - projection type (CZ version)
In the drawing environment start your Style editor and for the current standard set (the General tab or the View presets tab) the requested orthographic projection type - "First angle" (1st angle) or "Third angle" (3rd angle).
Inventor2010Inventor2009Inventor2008Inventor11
17.3.2009    23821×
Tip 12569:How to Explode a ViewBase generated from a 3D model?
Tip 12053:Analysis of stability - will it upset?
Tip 11823:Associative dimensions in drawing views of a 3D model in AutoCAD.
Tip 9357:Intersection of a 3D curve with a 3D surface in AutoCAD.
Tip 9020:Three methods and three different results of measuring distance in a map.
CAD Studio is not responsible for possible problems that may occur as a result of using any of these tips.
