  Visitors: 5554
CAD tip CAD tip # 6611:
AutoCAD reports PSELECT as an "Unknown command".
A - answer If PSELECT doesn't work in your AutoCAD, you have probably not opened the Properties window. This command is defined by default only for this window.
Open the Properties palette (Ctrl+1) at least once in your AutoCAD session and repeat the PSELECT command.
If you want to enable the PSELECT command automatically in every AutoCAD session, load the ARX extension acopm.arx - using the briefcase in Appload or with another ARX loading method.
ACADADTMapCivilACADMABS
1.4.2009    11548×
Tip 13683:Limitations of the LISP language (AutoLISP, VisualLISP) in AutoCAD LT - what to watch out for
Tip 12131:Error: no function definition: VLAX-ENAME->VLA-OBJECT or VLAX-VLA-OBJECT->ENAME
Tip 9689:Starting Fabrication CADmep 2014 in another AutoCAD - desktop icon.
Tip 9500:File loading warning - security concern (executable file).
Tip 9176:Confirm loading of LSP, VLX, DLL, ARX application files.
Add .CIT raster format support to AutoCAD and Map and Civil 3D
CITin More info
