  Visitors: 5776
CAD tip CAD tip # 6633:
What is the .ADSK file format used in Inventor or Revit?
A - answer ADSK is a data exchange format defined by Autodesk (available since versions 2010), based on XML. It used e.g. for transferring data between Inventor, Revit, AutoCAD Civil 3D and AutoCAD Architecture.
Its extendibility opens the possible future broader usage as a universal media for exchanging design data between CAD applications.
In the versions 2010 it is used e.g. in Inventor AEC Exchange (models for Revit MEP), you can open it in Revit, AutoCAD Civil 3D and Architecture.
A simple double-click on an .adsk file displays the documentation report created by the authoring application - ADSK format is "self-documenting":
ADSK report (Inventor CZ)
Before using ADSK file transfers apply the latest hotfixes for your CAD application.
ACADInventorRevitCivilADTDWG
21.4.2009    32550×
applies to: AutoCAD · Inventor · Revit · Civil 3D · AutoCAD Architecture · DWG ·
Tip 14085:JavaScript API support in AutoCAD and AutoCAD LT.
Tip 13988:How do I uninstall hotfixes, updates and apps that cannot be uninstalled via Control Panel?
Tip 12833:RAL color library (palette) for Fusion 360 (plus BS, AS, NCS).
Tip 12184:Overview of CAD formats supported in Inventor 2020 (import/export/AnyCAD).
Tip 10797:Cascading precedence of rental licenses.
