  Visitors: 10001
CAD tip CAD tip # 827:
How to plot a mirrored drawing?
A - answer Before print run the _-VIEW _Bottom command in model space (2D drawings only).
Some plotters also support plot job mirroring option on front panel. If you are plotting to a PostScript device, you can plot to a file and postprocess the PS file with some PS utility to mirror it.
ACADLT
8.12.2000    7897×
Prices - CAD eShop:
applies to: AutoCAD · AutoCAD LT ·
Tip 13358:Restore the last deleted entity in the DWG.
Tip 12237:UnfoldRS - unfold 3D surfaces to 2D in AutoCAD.
Tip 11404:Operations with attributes inside a block - fields.
Tip 11198:Justified attribute text in mirrored blocks (AutoCAD)
Tip 11111:Inventor drawing diplays flipped, mirrored (as from underside)
LogOff 2006 More info
