CAD tip # 7145:
applies to: AutoCAD · |
Tip 13827: | Snap points to the nearest curve/polyline with Snap2Curve. |
Tip 13788: | Green square - mathematical charade and parametric constraints in AutoCAD. |
Tip 13769: | Connect points by a list of point numbers - PoNum. |
Tip 13767: | How to copy a DWG object to existing points? |
Tip 13737: | Formatting leading zeros in AutoCAD fields (and automatic field update). |
Featuring: Use Google Earth images in your AutoCAD projects with the Plex.Earth Tools ![]() |
