  Visitors: 5744
CAD tip CAD tip # 7185:
Revit batch print utility.
A - answer To perform batch print of Revit projects you will need first to download and install the additional tool "Batch Print for Revit" (available on your Subscription Center; included in Revit since 2018).
The Batch Print function (prints on the default printer) can be then found in the ribbon Tools > External tools > Batch Print. In the "Batch Print" dialog, check all requested views and drawings to print (plot) and on the "Rearrange" tab specify the order of printing for the individual sheets.
Batch Print is compatible with both the English and localized versions of Revit Architecture, Structure and MEP, in the versions 2009 and higher.
Revit2010Revit2009
27.1.2010    16908×
Prices - CAD eShop:
applies to: Revit 2010 · Revit 2009 ·
Tip 11953:How to save PDF/A-1a archive from CAD software AutoCAD, Inventor, Revit?
Tip 11604:How to set plot transparency for all layouts in a DWG?
Tip 10461:Unattended DWG plotting and PDF publishing without AutoCAD.
Tip 9968:Batch conversion of CAD files from/to the IPT/IAM, STEP, IGES, SAT, Catia... formats
Tip 9147:Batch publishing to PDF uses different margins than single prints.
