  Visitors: 8936
CAD tip CAD tip # 9850:
Revit crashes on startup: An unrecoverable error has occurred
A - answer Revit 2013 or 2014 crashes just after launch with the error message:
An unrecoverable error has occurred. The program will now be terminated. All of your data has been recently saved, so there is no need to create recovery files.
resp. (in German):
Es ist ein Fehler aufgetreten, der nicht behoben werden kann. Das Programm wird jetzt beendet. Alle Daten wurden kürzlich gespeichert. Das Erstellen einer Wiederherstellungsdatei ist nicht erforderlich.
resp. (in French):
Une erreur bloquante s'est produite. Le programme va être refermé. Toutes vos données ont récemment été enregistrées, vous ne devez donc pas créer de fichiers de récupération.
resp. (in Italian):
Si è verificato un errore irreversibile. L'applicazione verrà terminata. Tutti i dati sono stati salvati di recente, quindi non è necessario creare file di recupero.
resp. (in Spanish):
Error irrecuperable. El programa se cerrará. Todos sus datos se han guardado recientemente y no es necesario crear archivos de recuperación.
You have probably not installed Revit as a user, but it was installed for you by an Administrator or as a network deployment, and at the same time you are using one of the plug-in applications from Autodesk Apps Exchange.
This problem is caused by improper setting of access priviledges to the "manifest" file, too low user access rights to the file PackageContents.xml created by the Apps Exchange installator. This file is included in all modern add-on applications for Revit.
So it is neccessary to locate all files PackageContents.xml in the path C:\ProgramData\Autodesk\ApplicationPlugins\…\ and check (and probably elevate) their access priviledges for the current user.
Revit2014Revit2013
30.5.2014    17471×
Prices - CAD eShop:
applies to: Revit 2014 · Revit 2013 ·
Tip 13692:What is the precision in Revit?
Tip 13539:Revit 2023.1 shows "Twinmotion is not installed"
Tip 13409:How to create Revit Window and Door schedules with legend views?
Tip 13227:Reference Explorer - quick analysis of your project or assembly (file size, xref errors).
Tip 13105:Error - user license revoked.
