  Visitors: 5664
CAD tip CAD tip # 8142:
Revit error message: Line is too short
A - answer The error message (warning) "Line is too short" indicates an underflow of the value with the minimal length of the geometry as supported by Revit.
Due to the internal representation of the object sizes, the minimum line length in Revit is limited to 1/32", resp. 0.75 mm.
This error usually indicates another problem in the drawing (e.g. an invalid coordinate entry).
Revit
16.8.2011    13649×
Prices - CAD eShop:
applies to: Revit ·
Tip 13692:What is the precision in Revit?
Tip 13539:Revit 2023.1 shows "Twinmotion is not installed"
Tip 13409:How to create Revit Window and Door schedules with legend views?
Tip 13227:Reference Explorer - quick analysis of your project or assembly (file size, xref errors).
Tip 13105:Error - user license revoked.
Add .CIT raster format support to AutoCAD and Map and Civil 3D
CITin More info
