  Visitors: 6025
CAD tip CAD tip # 10612:
Revit error: Unable to open because of unresolved pointer references​
A - answer When trying to open a RVT or RFA file, Revit displays the error message:
Unable to open because of unresolved pointer references​. Contact Autodesk Support.
This problem may be caused by a corrupted Revit file (e.g. due to a communication error, hardware problem, virus, edits in an incompatible program), or by a disrupted licensing mechanism.
Try to open the complaining file with the Audit option checked:
If it is a central model, try to copy it under a different name to the same folder and open it with the option "Detach from central".
If these steps will not help, look for a backup file, a journal, or send the file to Autodesk Support through your subscription account for an recovery attempt.
Revit
26.11.2015    8953×
Prices - CAD eShop:
applies to: Revit ·
