  Visitors: 8844
CAD tip CAD tip # 10866:
Revit LT 2017 in more, "secret" languages.
A - answer The entry-level BIM application Autodesk Revit LT was always available in a limited number of language localizations. The new version Revit LT 2017 changes the game.
The new Revit LT 2017 is distributed as a multilanguage version supporting English, French, German, Italian, Japanese, Korean, Polish and Spanish. Other languages like Chinese, Portuguese, Czech or Russian are not officially supported and the product installer does not offer them.
But the required localization files are included in the installation and so you can launch Revit LT 2017 in additional, "secret" languages - e.g. in Chinese or Russian:
  1. On your Desktop or in the Start menu, right-click on the Revit LT 2017 icon and choose Properties
  2. In the Shortcut tab, change the command in the Target field -> change the three-letter language code to e.g. CSY (or RUS, PTB, CHS, CHT)
    "C:\Program Files\Autodesk\Revit LT 2017\Revit.exe" /language CSY
  3. Click the OK button
Now the application startup icon will launch the localized version of Revit LT.
Revit2017
28.4.2016    4594×
Prices - CAD eShop:
applies to: Revit 2017 ·
Tip 10702:How to find which AutoCAD version was used to save a particular DWG drawing?
Tip 10283:Where to find Language Packs for Revit 2016?
Tip 8765:How to get and install a localization for Revit 2013?
Tip 7185:Revit batch print utility.
Tip 6341:My KeyboardShortcuts.txt file is in a wrong language.
