  Visitors: 7402
CAD tip CAD tip # 7167:
Search CAD blocks directly in Windows 7 Search.
A - answer Using the technology of "federalized" search and the OpenSearch format you can directly use the native Windows 7 search window to search CAD blocks form the CAD Blocks catalog (www.cadforum.cz/catalog_en) on this server.
On a computer running Windows 7 (Enterprise or Ultimate) download the XML file CF.osdx (right-click, save target as) from the block catalog. Double-click ("run") the local copy of this file and confirm the installation of the search connector.
Now choose Search (Windows > Start, or Explorer) and enter a keyword to find - e.g. "FORD". In the search results window go to (click) the item "CAD Forum blocks" and in the results you can see all DWG, RFA and IPT blocks containing the searched keyword, including thumbnails and other information. You can switch the view mode to list the blocks as thumbnails (different sizes) or detailed records. Display the preview pane to go quickly to the download page of the specific block.
Search results (CZ version)
DWGACAD
100% Win7  CAD
15.1.2010    13495×
Prices - CAD eShop:
applies to: DWG · AutoCAD ·
Tip 8834:Inventor assembly properties on the LCD panel of your 3D mouse.
Tip 6914:Running process WSCommCntr1.exe
Tip 6159:Subscribing CAD Forum and CAD Studio web contents directly in the AutoCAD window.
Increase your productivity with our set of add-on functions for AutoCAD Civil 3D
CADstudio Civil Tools More info
